Schematic 51 8N
BobV
First I want to thank everyone for response to the rivet on the fenders. I am going to use the ribbed carriage bolts, don't like to leave unpainted surfaces.
The next question where can I see a good printable schematic for my 8N, I have replaced the wiring with a new harness.
Get out your essential Ford 8N owners manuals. They ALL have 'schematics' with the original wiring shown. Are you restoring it to original 6-volt/positive ground specs? Be aware that unless your newly purchased wiring harness is an exact-as-original made one using the cloth covered correct color coded wires, you cannot just go by colors. Colors do not conduct electrons. Most aftermarket wiring harnesses do not follow the original color codes, but regardless of what you use, test with a multi-meter or continuity tester. Also, nnalert SELLS FENDER RIVETS -see LINK.
FORD 8N ESSENTIAL OWNERS MANUALS:
FORD 8N TRACTOR DASH WIRING:
Tim Daley(MI)
FENDER RIVETS
