Making headway on this. Just couldn't believe how much hard pulling it took to pull out the Rocker Assy. feed tube. finally got it out.
Got the oil pan off yesterday. The drain plug screen had separated and I found what I think are remnants of what has to be a governor.
Inside the housing showed wear and some minor damage. The governor that came out doesn't look like the MPC one. Anyone care to weigh in ?
The block where the water pump mounts looks like it also had some work done. Haven't got pistons out yet, but there aren't any oversize stamps on them.
The inside of the governor housing & Timing gear housing are nearly spotless. No residue, and the two oil pan to timing gear housing bolts had silicone on them. Apparently had been off before ?
