(quoted from post at 19:16:55 05/14/18) They were made to be
overhauled in the field by farmers
You have been hang'N out on the N board to long...
That is a made up statement and you know it. If that were true they would have put a zipper on the engine are made ware parts adjustable. The fact that they are of a low RPM engine also has nuttin to do with it they can turn double the RPM and live just as long a life. The RPM is governed because it would be a run away train if it were not.
I wrote this on Saturday and wasn't going to post it, but on second thought.
UD,
You might have to eat crow.
You wrote:
That's good advice for an expensive engine
TOH. But for a cheap N engine it's overkill.
I'll bet not one in twenty of these engines
that go to the machine shop get that kind of
white glove treatment.
It's too expensive. They were made to be
overhauled in the field by farmers - slap
bearing shells in them and get another
couple of seasons out of it. If someone
wishes to treat them so daintily, have at
it. But they will still do a lot of work for
a long time with the crudest of overhauls.
I think this is where your advice fell short and where the adversity ensued:
That fact that a farmer could take a stab at his own fix and partially succeed isn't even close to a testimony that an N engine is cheap; but on the contrary, it is the proof that as Hobo said, these engines initially got the critical-to-performance-and-longevity "white glove treatment" at the factory in terms of design, tolerances and balance. There's no way the engines could have had the snot worked out of them for so many years without having had the best of engine machine specs at play right out of the gate.
"If one wished to treat them so daintily" is also a total mischaracterization, of sensibly approaching rebuilds or refurbs judiciously, fastidiously, with all due respect for machine shop tolerances. Anything less is going to amount to good money after bad, wasted time and a disappointing, oil burning, knocking engine down the road with the owner never sure when the machine will let him down.
Terry
