lastcowboy32
Good morning gents.
I had my 2N in the barn for most of the winter. I only started it up a few times here and there to get the cobwebs out of it.
Every time I did, I would always let it run for 15 minutes or so; just to make sure it got warmed up and put some juice back in the battery.
Well, I've used it a couple of times this spring, and it's getting harder and harder to start. Runs fine... but my battery voltage is about 6V... and it's the same when the tractor is running.
I have an analog voltmeter, I measured the voltage between the single post on the back of the generator and various points on the frame.
Zero...nothing...nada...zip.
I tried my voltmeter in both polarities...just on the odd chance that I was trying the wrong polarity and the needle was trying to go negative (which it can't)... same thing.
The generator is also cold. I seem to remember that it would warm up after a while when it was running correctly.
My first guess is that my generator is shot. I haven't disconnected the battery all winter...so it shouldn't need to be polarized. Correct?
I'm questioning myself, though...because I've run this tractor for quite a while the last time that I started it. How long will these old girls run the ignition off of the battery if the generator is dead? Seems like darn near forever.
Am I missing anything?
My next step, unless someone tells me that I've missed something is to take the generator down to a local guy who tests and rebuilds such things.
Thanks and have a good morning all.
