boxzer8907
Well after waking up the old girl from her winter slumber she Is defiantly not right as of right now. I have her sounding like its running great but no power under a load. Example 4 gear or cultivating the ground with a spring tooth. It will just chug out and die or start missing with black smoke coming out the tailpipe.
Thought it was a electrical issue as I have had in the past so I started there. New points, cap rotor, coil an spark plugs. Wires are newer and are getting very good spark. I even double check all my plug gaps and points.
Then went to fuel. Cleaned the fuel bowl and carburetor. I checked for flow and seems to be good.
As of right now I can only think of 2 more ideas to check. Compression and governor. Any additional ideas would be greatly appreciated or situational knowledge.
