I don't have enough to be giving up any more. I have a new to me 1948 8n front mount distributor. It sputters and dies above 2/3 to 3/4 throttle. I put a new water pump on it. It came with a new carb and distributor installed. I did a tune-up (new points, condenser, plugs, wires, not coil). Also rebuilt the carb with an ultrasonic bath. Check the fuel flow and fuel filters. It runs if I pull the main needle out or choke the engine. The tractor had set for at least 5 years before I got it. The plugs were sooty black when I pulled them. I'm running out of ideas. I figure that it is in the fuel system.
Thanks, Bill
Thanks, Bill
