Farmall plowboy
To start I am unable to post pictures, I am asking for what its worth. Sitting next to the
road is a Ford 600 with backhoe and loader. Backhoe is a ford brand as well as the loader,
small bucket on the front hyd. operated. Tires are pretty good, tractor itself don't look
welded on, appears to have a hi/low trans. regular 3 speed with reverse, sheet metal is ok
fenders could use some work, engine looks to be in good shape, no major leaks, hoses on hoe
and loader are cracked and worn. Wasn't able to talk to owner, my guess is it was used for
grave digging.... The tractor is in WI. if that helps with value, any ideas? Thanks Craig
