NAA Refurbish
Two0aks
So I've decided to rebuild the 134 engine. To the originalists out there, are all or any rebuild parts U.S.A. made, or do we have to settle for that darn import junk. And as with everything else on this tractor thats a fastener, I've wire wheeled vigorously to remove rust but the rust has eaten into the zinc plating and I don't want to replace every nut and bolt just to have it look original only because all the fasteners are probably marked with China or India. Soooo they will be painted. I'm sorry. Any good used intake/exhaust manifolds out there ?
I rebuilt/upgraded my NAA over three years. Every part was OEM, if available, and most parts were located. Every bolt except flywheel and rear end ring gear bolts were replaced by new grade 8 bolts. All bearings in tractor and both trannys is American made.
Find a good CNH dealer and make friends with the parts guys. He can do a 'locate' for obscure parts.
