I am having problem getting my starter to operate correctly. I have rewired the tractor, it is an 8N, to a 12 volt system with a one wire alternator. I have 12 V to the switch, the terminal, the ammeter and the right side of the solenoid, and to the alternator and to the coil. My problem, is the new switch that I put in will not engage the starter. I suspected the solenoid, so I replaced it with a new one. I still get nothing. I took the yellow wire that goes from the top of the solenoid to the start button and put it to ground and still nothing. I tried touching the pos. battery cable to the left side of the solenoid and it turned over, but the wire got very hot, I only turned it for a couple seconds. I am at a loss for ideas, unless they sold me a bad solenoid. This thing started right up and ran last fall, but sat over the winter and would not start this spring. Had a bunch of crazy switches and wiring issues so I thought I would do it right. Would appreciate any ideas that might help.
