Need a front pulley to Jubilee
Geo-TH,In
Where can i buy front pulley to Jubilee?
Thanks
Geo-TH,There is one on ebay right now,welcome back!
https://www.ebay.com/itm/Ford-Tractor-Jubilee-Engine-Front-Pulley-W-Hub-Wide-Belt/362299677785?hash=item545abe5c59:g:dwsAAOSwvABa2rAB
https://www.ebay.com/itm/Ford-Jubilee-Tractor-Original-Crankshaft-Pulley/202285431572?hash=item2f1926bb14:g:5NsAAOSwOyJazSCK
Pulley
Den,
Thanks for looking. The pulley on ebay doesn't have an open center, mine does. The harmonic balancer attaches to pulley using same 4 bolt pattern. Only pulley on YT is a 3.5 inch generator pulley.
thanks.
Den,
After looking at all pulleys for 2n, 9n, 8n, and newer 600+ I'm having second thoughts. The pulley you posted may be what I need. I've asked seller to send me the measurements on ID of pulley minus hub.
Many thanks.
George
Hiya George.
You're back. That was quite a long hiatus.
You might ask this on the Ford board too.
Those guys would likely know if the front pully is the same on all the Red Tigers.
I know Fordfarmer there has parts for a 134 that got a rod punched through the side of the block.
He may have a pully for sale.
Basic front pulley (D7NN6A312A) appears to be still available from FIAT, but for just under $200! Mite be ale to find one on-line more easily with the part number.
Here's a list of possible part numbers, old and new...
<img src = http://oi67.tinypic.com/az7241.jpg">
Source
https://www.ebay.com/itm/NAA-600-640-641-601-800-840-801-900-901-2000-4000-FORD-TRACTOR-DOUBLE-PULLEY/362126819315?hash=item545070bff3:g:vfQAAOxyW1NREU4F
Click on above.
