Is gas cutoff story la myth?
I?ve always heard that you should cut off the fuel cutoff when
you finish using the tractor or the gas will get into the oil pan
and contaminate the oil.
I find nothing in the manuals to support this. It seems it?s
purpose is so you can shut off the fuel so you can clean out
the sediment bowl.
Seems the floats in the carb would prevent flow to the carb
when it is full.
Also, I?m not sure how fuel could make its way to the oil pan
from the carb.
What do you think. As smart as Henry Ford was did he
overlook this?
(quoted from post at 13:26:17 04/16/18) I?ve always heard that you should cut off the fuel cutoff when
the sediment bowl.
when it is full.
from the carb.
overlook this?
It's not true. If it was a lot of engines would have been ruined by now. The only reason I ever shut the fuel off is to clean out sediment bowl, or if I have a known leak and don't want to lose any gasoline while the tractor is sitting unused.
I always turn off the fuel valve and allow the engine to consume the gasoline in the carburetor before turning off the ignition on gravity flow fuel systems.
Yes, a properly working float/needle valve/seat system will prevent fuel from overflowing the float bowl, but such systems are known to fail for various reasons. If the fuel flow control system in the carburetor fails, fuel will overflow the float bowl and either run out onto the ground or fill the intake manifold and run into the engine.
Why take such chance?
Dean
No, it's not a myth.
See tip # 9.
" I find nothing in the manuals to support this."
Nor will you find anything in the manuals telling you not to have an open flame around the gas tank. Sometimes common sense prevails. Henry had a fuel cut-off on his 4.8 million Model A Fords from 1928 to 1931. He didn't need to tell tractor owners to cut the gas off; it was common sense.
This is one of the things that can happen if oil gets in the gas:
" We just had an 8N in the shop that the owner wanted us to fix the carb leak and replace the starter because the engine wouldn"t turn over. Turns out the base had more gas in it than oil and the bearings didn"t get enough lube from the diluted oil and seized the engine. I think of that tractor every time I park my tractors now and don"t forget to shut the fuel off."
(YT Post 10/10/07)
75 Tips
It's not a myth. What will happen if the needle valve sticks open?
" If it was a lot of engines would have been ruined by now. "
Well, some were.
Why take the chance?
(YT Post 10/10/07)
75 Tips
I do the same thing. It should always be done especially with downflow carburetors.
Happened to me on a '45 2N. Resulted in a hydrolock and and contaminated gas in the crankcase.
(quoted from post at 07:26:17 04/16/18) I?ve always heard that you should cut off the fuel cutoff when
the sediment bowl.
when it is full.
from the carb.
overlook this?
Roy, it's not a matter of whether it's POSSIBLE for the carb inlet valve to fail to seat and run your gasoline out on the ground and possibly into the engine, as well. (Even though you haven't wrapped your mind around how the gasoline can find it's way to the crankcase, rest assured it CAN and WILL.)
It's a matter of WHEN that will happen. If you keep the tractor around long enough, sooner or later it WILL happen.
Closing the fuel tank valve is simply like insurance, you hope you never need it, but sooner or later you WILL.
And if the tractor happens to be in an enclosed area with a possible ignition source, the precaution of shutting of the fuel during periods of non-use could very well prevent a fire or explosion.
I have a pretty good habit of turning it off, turning it back on is a different story, I can't count the times I get about 50' and it dies.
Thanks for all the replies
I?ve always done it religiously, but I?ve always wondered why. I?ll keep own doing it.
I shut the gas off on all my tractors and riding mowers. I've had more trouble with the mowers leaking gas into the crankcase than my tractors.
One thing that the others have not mentioned is to be sure and always turn the gas off when hauling a tractor. The trailer bouncing will bounce the float in he carb and definitely cause it to flood.I have seen it happen many times.
In all my years working around, and repairing, tractor engines have I ever experienced, or heard of, an engine filling up with gas due to a leaky needle valve. The only tractor engine I can think of that this would be possible is any two cylinder John Deere engine. If you feel it's a good idea to shut off the fuel valve when you are done using it, have at it. It certainly won't hurt anything.
Perhaps it helps to consider the difference in fuel systems used in tractors, motorcycles versus cars of the carburetor era.
- The N series tractors (and many others) use a gravity flow fuel system. In this system the fuel tank is located above the carburetor and fuel flows to the carburetor without the need for a fuel pump. If for any reason the float needle valve does not seal completely the entire contents of the fuel tank can be emptied. The N series carburetor has a vent to accommodate this leakage. If the vent works as intended the fuel leaks onto the ground rather than filling the engine cylinders/crankcase with fuel. However, you still have a mess and/or a fire hazard.
- Cars and trucks typically use a fuel tank mounted below the below the carburetor. This system requires the use of a fuel pump to push fuel to the carburetor. If for any reason the float needle valve does not seal completely the fuel remains in the fuel tank, since there is no pump operation to push it to the carburetor. No fuel leakage results as the vehicle sits.
- Motorcycles of this era also used a gravity flow fuel system with the fuel tank above the carburetor. The carburetors typically had an over flow pipe within the float bowl. In the event the fuel level increased above the open end of the pipe the fuel would be routed through an over flow hose to the ground. If all worked as intended the over flow fuel would not fill the engine cylinders/crankcase. However, you still have a mess and/or a fire hazard. Most manuals for motorcycles do contain a note, stating the fuel petcock must be shut off when the motorcycle is not in use.
" In all my years working around, and repairing, tractor engines have I ever experienced, or heard of, an engine filling up with gas due to a leaky needle valve. "
Well, now you have heard of it from multiple sources.
75 Tips
(quoted from post at 09:52:36 04/16/18)
ust because one person has not seen an event is not proof that such event can not happen. Picture shows how it happens. Once intake manifold is full, gas passes valves, piston rings and on into crankcase. Yes it does mean that the carb base sintered-bass drain hole is plugged and yes that is a common situation.
I personally have yet another reason for turning off the supply and not doing so has caused me this problem many times in tractors and small engines such as ATVs. It sits for weeks with the float holding in a closed position. Needle sticks, starts & run a few seconds until bowl runs dry (carb work or hammer now in order). Whereas, when I turn off supply valve, run until carb bowl dry, the float has dropped/needle off its seat (where it can not stick to seat) and next time I turn on the supply valve all functions normally without any problem for me to solve. I like it and it works for me!
On most anything you use with an engine that has a gravity fed fuel system on it, there will be a fuel shut off valve. Why do you think that is?
Did it on a ih cub in my barn, and on a brigs powered mower, in my garage.
If you haven't seen it, you simply haven't worked on enough old junk for long enough.
Lots of good information.
I?m convinced that I should cut off the fuel when I shut down.
I particularly liked Dean?s method to shut fuel off and let it empty out before switching it off
This would help in remembering to cut it off.
I can remember one night I had to get up out of bed and shut it because I forgot.
81 years old and in the forgetful years :)
(quoted from post at 07:22:12 04/16/18) " In all my years working around, and repairing, tractor engines have I ever experienced, or heard of, an engine filling up with gas due to a leaky needle valve. "
75 Tips
One more: I’ve not had this happen on my ‘50 8N, as I always turn the fuel off when done. But I did have it happen some years ago on my ‘71 VW van, which had no shutoff. Thankfully, no smokers dropped a butt near the vehicle, as there was a large puddle running out from underneath. Stuck float valve was the culprit.
es
This is one of the things that can happen if oil gets in the gas: ?
Hows that,I would like to know how that happens?
(quoted from post at 13:31:52 04/16/18) This is one of the things that can happen if oil gets in the gas: ?
ord transposition? Read what is intended, not what you see! :)
(quoted from post at 08:52:36 04/16/18) One thing that the others have not mentioned is to be sure and always turn the gas off when hauling a tractor. The trailer bouncing will bounce the float in he carb and definitely cause it to flood.I have seen it happen many times.
Welding Man is so right!! My John Deere G was hauled here from Nebraska and left there with a full fuel tank. When it got here the tank was dry. Turned out I had 17 gallons of mogas plus 11 quarts of oil in the crankcase. Thank goodness I didn't try to start it!!! Agreed, the engine is different than an 8N, but it can happen and will--
(quoted from post at 15:22:12 04/16/18) " In all my years working around, and repairing, tractor engines have I ever experienced, or heard of, an engine filling up with gas due to a leaky needle valve. "
75 Tips
I've used and worked on many brands and types of engines in my lifetime. I did have a John Deere model B that filled one cylinder full of gas over night. I had to open the compression relief petcock located under the engine block to drain out the gas. Being young and impatient I mash down on the starter button to help push the gas out. Only I for got to turn off the ignition switch before doing that. That's when I learned about snow not being an effective fire extinguisher. I did get the fire put out, but had to go back to the house to make an adjustment to my underdrawers.
The way I look at an issue with leaky anything is to fix it before something bad can happen. Making sure the sintered-bass drain hole isn't plugged is another thing that should be kept clear. That and a can of Seafoam in the gas tank once in a while helps prevent needle valves from sticking. Relying on shutting off the fuel every time you are done using the tractor has one fault, and that is your memory. I'm sure a lot of us have forgotten important details once in a while in the course of our days. Forgetting to turn off a fuel valve is one of them. Letting another person use our tractors is another. You may tell them about shutting off the gas, but they may forget about it too. So shut off the valve if you feel you must do it, but try adding a few things to your yearly maintenance to help prevent your carburetors from overflowing and making a mess.
If the gas is up here and the motor is down here .. That chicken sh^%$t little needle valve is all that stands between you and an empty tank or a ruined tractor engine. Or worse, a fire that burns something down.
What wasn't mentioned by all the "valve off, run until it dies" folks is when they forget to turn the key OFF... if they're most fortunate, the engine stops with the points Open... if the points are NOT open, they'll be the 'first to know' when they intend to use the tractor next time...
(quoted from post at 11:41:48 04/16/18) What wasn't mentioned by all the "valve off, run until it dies" folks is when they forget to turn the key OFF... if they're most fortunate, the engine stops with the points Open... if the points are NOT open, they'll be the 'first to know' when they intend to use the tractor next time...
That's why it's best to not get off the tractor until the engine quits if you do that.
Guess Ive been lucky. I have never shut a gas valve in over 50 years, and many tractors. Probably should, but thats my story. Never had a problem either.
(quoted from post at 13:39:16 04/16/18) Guess Ive been lucky. I have never shut a gas valve in over 50 years, and many tractors. Probably should, but thats my story. Never had a problem either.
Well...tomorrow could be the day, couldn't it? I guess you're going to count on your lucky streak continuing, right?
I've done it several times on my '49 - luckily, I checked the oil before I went to start it - both times, oily gas ran out the dipstick tube.....
Honestly didn't know there was even a bowl vent on these things - Marvel Schebler carb on mine, not a Zenith, did they both have 'em? Will have to clean it out, though.
Usually burn it dry, now, with "new" gas - sick of taking the carb apart and cleaning it every time I go to use it.
I have a 1946 Cessna 140 airplane. It has two gravity fed fuel tanks, one in each wing. I always turn the fuel valve off when I'm done flying. If I don't shut the fuel off I'm depending on the carb float valve to hold back 25 gallons of fuel from dumping out on my hanger floor. Major fire risk to my hanger and all the others connected to mine. Same with my 8n, the fuel is always shut off when she's not in use. It's so easy to prevent a major disaster.
Sheesh.
A lot of worry warts here.
Of the million Ns over the last 70 years I suppose this flooding has occurred 100,000 times.
On any given day you'd probably stand a better chance of winning the powerball than have this happen to you.
Besides, doesn't anyone check their oil and gas before they fire up their tractor?
(quoted from post at 15:54:14 04/16/18) Sheesh.
Of course that begs the question...do you turn yours off?
I've gone 73 years without getting killed in an auto accident but I still use my seat every time.
Besides, even though you check your oil every time, if it happens to you, you still have that mess to clean up.
Caryc,
No, I don't turn mine off.
Never have.
I don't mind if you do and I won't tell
people not to shut them off. If it makes
you feel better, do it.
But...
The urgency of some of the replies to this
thread just makes me wonder about people.
(quoted from post at 19:34:48 04/16/18)
ey, Caryc, I do believe UD's tractor has a fuel pump. :)
(quoted from post at 23:54:14 04/16/18) Sheesh.
I've realized that about this group of tractor enthusiast. They think the engine will fall apart if the gas they use is over a couple of weeks old. I've had tractors that sat outside with a half tank of gas for a year or two. The gas would smell so skunky the dogs wouldn't even go near it. Put jumper cables on the battery and fire it right up. Then use the tractor until it's low on fuel and never have a bit of trouble with it.
I've had it happen on my seasonal Cyclone leaf Rake 10 hp briggs that I stored dry and ran all fuel out of carb. When I filled up the fuel tank to start it after 6 months, the seat didn't seat, and I noticed the recoil starter would not pull (remember liquids do not compress). Confounded until I noticed gas running out of the muffler ! Good way to bend a rod and lot's of other bad things. I follow Dean's method. Turn off fuel, and let it run for a minute to take some of the hydrostatic head off the carb before turning off.
(quoted from post at 17:01:31 04/16/18)
Well, excuse me. This is an "N" forum so I kind of figured he had an "N". I've never seen a "N" with a fuel pump...a stock "N" that is.
i feel the need to pay homage to my favorite film.
George: All I said was that our son, the apple of our three eyes - Martha being a cyclops - our son is a beanbag, and you get testy!
Nick: I'm tired, I've been drinking since nine o'clock, my wife is vomiting, there's been a lot of screaming going on around here!
George: So you get testy, naturally, don't worry about it! Anybody who comes here ends up getting testy, it's expected. Don't be upset.
Nick: I'm not upset.
George: You're testy.
Nick: Yes.
(quoted from post at 22:26:13 04/16/18)
o excusing necessary.........I was pointing out that UD was likely doing his usual 'stirring the pot'!
I’ll add another vote for turning it OFF.
If I leave it one even just overnight it’s a bit** to start the next day. It doesn’t dilute my crankcase. It makes loooots of black smoke(pretty cool if you like that sorta thing), but doesn’t work when I NEED it.
Yeah, yeah fix what’s broke, I’d be fixing Chinese junk non-viton tipped needles till the cows come home.
Either plumb it straight from the tank or use that knob the way it was intended. It takes sooo much effort to crank on it for all of 15 seconds.
If you choose to not to use it, either you’re exceedingly lucky or lazy. My vote goes to the latter.
Funny how people people nit pick over ring end gap, but won’t expend such little effort over a little knob.
Every motorcycle has an automatic fuel shutoff to stop the gravity feed from pushing past the needle, years ago we always shut the fuel manually. Even my Chinese scooter has a vacum actuated fuel shutoff so it doesn't flood the motor. I'm sure one could be adapted to an N.
Dad never did turn the thing off and neither did I for al the years we owned/used it... To each his own...
(quoted from post at 22:07:35 04/16/18) Dad never did turn the thing off and neither did I for al the years we owned/used it... To each his own...
I takes a few seconds to turn that little valve off. How much time, effort and money does it take to have to drain the crank case and add all new oil?
You've seen people here say it actually happened to them. So you know it can happen. Isn't it worth the simple effort to turn it off?
While we're on the subject . . .
Last month I put premium grade gas in the tractor and the next day, my valve went from being so loose I could turn it with one finger against my little knob pointer, to so hard to turn it had me worried.
So as people here said to conclude, I also concluded it was ethanol in the fuel. But the service station assured me there was zero ethanol in their fuel — which may or may not be true I guess.
Anyway . . . I drained the tank and put in what I had been using before that, "Mid Grade" marked gas. Bingo! Two days later the knob was back to feeling normal and actually a little better because it seemed so easy to rotate before, that I half expected it to start leaking one day soon.
So if there is indeed no ethanol in this company's fuel, then there's something about this HyTest fuel (or any Premium fuel maybe) that swelled up the stem seal.
Speaking of pots...
If I had set out to stir the pot I might
have suggested they convert to 12V and add
an in-line electric shut off valve.
I might also have suggested they dispense
with their old gravity job and buy a newer
tractor that has a fuel pump - or maybe, is
a diesel. Remind them they'd get more
sleep, more gears and maybe power steering.
My point was not whether to turn your fuel
off but the grave warnings and dire worst
case scenarios that were brought up if you
don't.
On the other hand, we all know your
penchant for calling the kettle black.
You have your answer as shown by all the replies. I'll just add this from the original '9N INSTRUCTION BOOK': "When tractor is to be idle for 30 days or more, drain the entire fuel system including the gasoline tank. Fuel should be removed through the bottom of carburetor, with Sediment Bulb Valve on "reserve" (means all the way fully open). Gasoline, when stored, forms a gum or wax which has a tendency to clog up the small pores and openings in the carburetor. For the same reason, do not use which has been stored for more than 60 days." The debate on ethanol mucking up these old systems will go on forever, and there is no need to run a Premium grade gasoline in these engines. The exception may be if one has an optional Sherman Hi-Compression aluminum head. As we see by the diagram of the Fuel Sediment Bulb Assembly, there is only one part that is essentially the working, or mechanical device and that is the valve stem. There is a seal and washer in it, and that is the piece that becomes worn and/or torn over use and needs to be replaced as leaking will occur. I've had some newer aftermarket valve stems that used cheap vinyl for the seal that failed out of the box. A new valve stem, p/n APN-9194, sells for about $6 and is much cheaper than buying a whole new sediment bulb assembly. Henry Ford was a frugal man, but with a very limited education. He couldn't read a blueprint, and left the technical side of things to his engineers. His only requirements were to build things as cheap as possible so as to make this products available to the average American consumer. He had certain stipulations, but had nothing to do with technicalities. If you are still a non-believer after all that has been said here, then take coffee can and place it underneath the carb, leave the valve stem open 2 turns, and leave for a few weeks, or a month. Check can every week and then check oil and report back.
FORD TRACTOR SEDIMENT BULB & VALVE STEM :
Shut'N the fuel off is not a natural thang its something that becomes natural to ya with repetition its sort of like locking your front door when you go in at night. For all practical porous the door will stay shut even if you don't lock it...
When I got my first Harley I knew from watching everyone kick there arse off they were temperamental. They learned fast to turn the fuel off when they shut it down I spec folks with hand crank tractors learned that also... I can tell you from experience after you kicked your arse off for 30 min. it became repetition to turn the fuel ON when you went to start your scooter :)....
Its sum'N you have to make yourself learn to do it only takes one bad experience to go into training mode... I started my career with old timers they had devised some neat tricks to overcome there lack of resources modern technology has eroded it away...
Something as simple as installing a fuel pump they would install the pump but leave it loose them manually rock the pump till it primed the system. Lack of resources like a battery charger are weak 6V systems that did not allow them to be able to crank on it till it picked up the fuel...
You do know that only two grades of fuel
are delivered to the gas station, mid is
a blend of the two
(quoted from post at 06:53:13 04/17/18) You do know that only two grades of fuel
a blend of the two
Market,
Thanks, I'll keep that in mind!
T
(quoted from post at 12:17:05 04/17/18)
a blend of the two
Market,
T
ut about 1 inch of water in a 16 OZ water bottle, then fill to about 3/4 full with gasoline, shake well, let set/settle for an hour +/- and see if water/separation level is still 1 inch. If still 1 inch, then ethanol free, if level at separation point increased, the fuel has ethanol in it. Google for pictures. I have performed this test more than once....it works. It is simple.
"The only tractor engine I can think of that this would be possible is any two cylinder John Deere engine."
JD even ran the shutoff valve handle up through the dash so you could shut it off from the seat of the tractor.
Most are just empty holes now, since the sediment bowl has been replaced, but the hole is still marked.
It really PO'd me on a Briggs and Stratton once. Hydro-locked right after a rebuild.
I had a Farmall BN that also leaked gas into the oil.
It had bad enough rings to leak it all into the oil and not hydro-lock.
Luckily, I noticed that the crankcase was over full.
It certainly happens. I personally think it happens now more than it used to.
I don't believe that's because of ethanol fuel so much as how these old tractors are used.
More specifically, the lack there of.
We never turned the fuel off on our JD 2 cylinders when I was a kid.
They were used almost daily.
Now, we turn it off every time but they're only used a few times a year.
And then there is the difference in parts quality too. Both needle AND seat.
(quoted from post at 19:24:56 04/17/18) "The only tractor engine I can think of that this would be possible is any two cylinder John Deere engine."
My two cylinder JD has a sediment bowl and shut not unlike my 8n's. I shut it off because the stem leaks, and it only get ran a few times a year.
I have an old TO35 Ferguson, I always cut the gas valve off,
Most times it will not leak, but every once in a while it will,
If it does you can normally smell fuel odor, just pull air inlet hose off and drain the fuel before you try to start engine,
In my book it?s just not worth taking a chance on lt leaking
I understand they even make an automatic fuel cutoff valve, you wire it to the ignition circuit so when you turn off the ignition, it turns off the fuel line valve,
My luck in time it would start leaking, so I just cut off valve myself,
(quoted from post at 21:37:03 04/17/18)
Still got the hole in the dash? I'm not sure what all models/years had that. My '46 A did and '53 50 does. So did my '54 60.
Not a myth. I've had it happen to me years ago on an 8n. Gas in the case will thin the oil so your oil pressure will drop. When a tractor that normally runs at about 20 on the oil pressure gauge than drop to about 2 the next day you know something ain't right. Luckily caught it in time.
I hope spring gets here soon, everyone's cabin fever is showing. LOL 4 pages on whether to shut off the gas, it is kind of funny. I always shut mine off and let the engine run until it stops. Thus, I have this never flooded the crank case on my 2N.
However I have a 2006 Snapper lawn mower, one of those red rear engine jobs. Same set up as our N's. Tank is above the engine, gravity feed. One spring ~2009, I went to start it and the motor would try to turn, but it could not turn over. I thought the battery was dead. Turned out the crank case was flooded with gasoline. It didn't even have a fuel shut off valve, it does now, LOL
I never thought I would say this, but I miss the days of the which is best. Volt or amp meter argument.
Yep when I was running those crappy 2-9-8 n fords for the neighbor in the 1960's the fuel had to be shut off every night. If you didn't it was a sure bet the darn things would not start the next morning. Even if you did shut off the fuel they were a problem starting.
(quoted from post at 12:10:15 04/18/18) Yep when I was running those crappy 2-9-8 n fords for the neighbor in the 1960's the fuel had to be shut off every night. If you didn't it was a sure bet the darn things would not start the next morning. Even if you did shut off the fuel they were a problem starting.
So...what are you doing on a "crappy" 9-2-8N forum?
