Trans/Diff. coupler
Denny K
Does anyone have one laying around that could measure the overall length and post it? # of splines and od? Also the dimension between the trans output shaft and the diff. pinion shaft if someone has it.
(quoted from post at 15:51:38 04/15/18) Does anyone have one laying around that could measure the overall length and post it? # of splines and od? Also the dimension between the trans output shaft and the diff. pinion shaft if someone has it.
I don't have the OAL but the splines are SAE parallel:
1.500 x 10B on pinion end
1.375 x 10B on transmission end
TOH
I have a drive shaft measuring 2 inches in diameter, 10 1/4 inches wide ,10 splined either end 1 3/8' on one end and 1 1/2' on the other.
