Completely dismantled the strg. gear yesterday. Plenty of oil still in it but not up to the fill plug. Surprising amount of debris in the bottom of the case. It took quite a few whacks with a hammer & wood block to dislodge the side covers. I couldn't tell if it had ever been rebuilt as it still had the cork & metal Sector shaft seal & retainers. Found a Alum. Tube just the right size to pop out the column seal. Dismantled & cleaned it. Still in good shape. QUESTION: The YT store shows two different priced replacement Sector Shaft seals. One is green, maybe CR. The other may be generic. Are these better than the original and have you ever had a leak afterwards ? This also had nine shims for a total of .038". Several quite rusty where they sat at the top of the case cutout. I did the check per FO-19 for worm shaft play. Non perceptible.
