(quoted from post at 14:47:50 03/23/18) Forks would be good for moving big rocks if you would use a
pallet with them
(quoted from post at 20:44:15 03/23/18) Terry, I asked that question once over on the Tractor Talk forum (using a single spike on the back of an 8N to dislodge rocks), but everybody replied that there would be too much danger of the front of the 8N rising up.
(quoted from post at 07:11:17 03/24/18) 1.) Yes on the forks, none of these will stand up to using the tines other than designed, for pallets etc. I moved a huge log with an agri supply set of tube frame/tines, 4'-0" diameter, exceeding the rating, they held up, but later when catching one tine in the dirt on a root or something, just tore away from the frame.
2.)Post a photo if you can of what the seller has. I knew that when I saw this set of Woods DuAl universal forks it would be an easy conversion, (it was) and would be the least expensive option to haul logs in from my 98 some odd acres. These adjust along the 1 3/8" rod, just unlatch the catch and move sideways as needed. I think I like the type that have the thick upper rail with notches better than the mild steel rod, they will take more abuse, but knowing that rod will bend, it means that will take the abuse and not break or bend something more substantial. I keep an extra rod on hand.
3.) I remember when you got that 110, they are a nice plow for the larger gardens, plots and similar. I thought, well I already have one, but decided what the heck. This one has a one piece moldboard with no separate shin, so it's different, also has a suffix in the serial number. I have see 2 other 110 over the years, but they don't come up often. Serial number makes one believe they made a lot of them though.
4.) Might be worth a try, but looking at both implements they are vastly different in some respects, the subsoiler is made of a stout piece of cutting edge like plate, not sure if hardened, but it's a lot bigger than a chisel plow shank, (at least ones I am familiar with) + its braced and is designed to penetrate deeper, ideally in dry, hard soil so it fractures the soil. I think the wear part on the cultivator is too wide for being used a subsoiler. Might work as a middle buster, say for potatoes or similar.
(quoted from post at 16:55:14 03/24/18) Yes great for picking up ground surface stuff but it don't have
down pressure for digging.
(quoted from post at 17:31:57 03/24/18)(quoted from post at 16:55:14 03/24/18) Yes great for picking up ground surface stuff but it don't have
Kirk,
Now there's something I wouldn't have thought of!
So a hydraulic top link isn't the be-all-end-all, after all,
cause it doesn't have the down pressure of a rigid top link.
thanks for that,
Terry
(quoted from post at 18:54:41 03/24/18) Cary,
You wrote:
"I don't understand what you mean. There is no down pressure on the 3 point lift system no matter what kind of top link you have."
The way I understood Kirk was that with the hydraulic top link being collapsible under implement pressure the [b:cb755f5184]tilt [/b:cb755f5184]of the implement isn't fixed as it is with a rigid top link.
(quoted from post at 19:20:25 03/24/18)
Oh, I see.
Just because it isn't double acting, doesn't mean it will give like a shock does. Good analogy!
Well then, I don't know what Kirk meant so I'm
back in the land of blissful ignorance awaiting resolution.
Thanks,
T
(quoted from post at 19:42:59 03/24/18)(quoted from post at 19:20:25 03/24/18)
Oh, I see.
Thanks,
T
You're still losing me but I'm trying to understand what you mean. No top link whether solid or hydraulic is going to have down pressure. There is no down pressure on the 3 point lift arms. If the 3 point had down pressure, it would just lift the back tires off the ground and you would have no traction.
There is a top link they make that has no hoses or a pump connected with it. It is still called a hydraulic top link because you can use the valves on each end of it to set the ram inside it where you want it. It will then stay in that position and won't move. It works like a double acting cylinder but you have to manually move it to the length you want then close both valves and it will stay at that length.
I think Hobo had it closer to your thinking when he said that if you have a set of forks on a rear bucket and angle the forks down it will dig itself into the ground just like a plow does depending on how much power your tractor has.
A plow digs itself into the ground yet there is no down pressure on it anywhere other than its own weight.
(quoted from post at 00:27:57 03/25/18)
I know knothing!
Ask Kirk!
Signed,
Manuel
(quoted from post at 22:25:13 03/24/18)(quoted from post at 00:27:57 03/25/18)
I know knothing!
Ask Kirk!
Signed,
Manuel
u wouldn't happen to be from barcelona, would u?
(quoted from post at 03:49:05 03/25/18) If the rocks will fit in your dirt scoop just reverse the scoop and adjust the toplink to angle down a little and scoop up the rock. if you don't want to take any dirt with it then get the scoop as close
as you can and walk the rock in with a rock bar. The hydraulic might help a little but not much. I move rock that size in my dirt scoop all the time. Sometimes I'll dig them out with a backhoe. This pile
of rocks from the garden started as a depression and i figured i'd level it out now it's just another rock pile on the property.Plenty of rock here. [color=red:87adb8232e][b:87adb8232e]My rock picker pulled 13 triaxles out of my property
last year. Average was 3 to 4 foot wide.[/b:87adb8232e][/color:87adb8232e]
(quoted from post at 03:24:10 03/25/18)(quoted from post at 22:25:13 03/24/18)(quoted from post at 00:27:57 03/25/18)
I know knothing!
Ask Kirk!
Signed,
Manuel
Si meestere Faulty
The only bad thing about Fawlty Towers is that they didn't make more.
Fawlty Towers will always be tearfully, heart stoppingly, deadly, and disasterously funny.
