(quoted from post at 21:38:16 03/22/18) I have done this before making a two bottom out of a three
bottom..
Take the first bottom off. Remove the second bottom with the
tailwheel and place into the one bottom position. I have seen
were guys have cut the rest of the second beam off but if you
take the second beam off you should be able to turn it upside
down and this way you can always put it back together as a two
bottom if you need too.
(quoted from post at 05:17:46 03/22/18)
I know I have read how to make a 2 bottom a 1 bottom plow... I am thinking about doing just that with the 10-8 I just picked up...
I always wanted a 1 bottom to plow a ditch and such... Do you move the second bottom and beam are jut remove the first bottom and replace it with the second bottom... :?:
(quoted from post at 15:00:02 03/22/18) You have a longer landside plus a heel on the landside so you
don't need a tailwheel.
Kirk
