(quoted from post at 07:07:39 03/18/18)
(quoted from post at 06:00:02 03/18/18) A customer sent us a picture of the oil tank on his wood splitter with spark from an oil leak on top ofthe tank. This is a Timberwolf with a Honda engine. Ant thoughts on how this would happen?
Mark
WAG - a manifestation of this phenomenon:
Electrostatic Discharge in Hydraulic Systems
TOH
A friend/neighbor of mine had a 10,000 gallon farm diesel fuel tank set up some years back with an electric pump to fill tractors that can take a coupe of hundred gallons of fuel at a time.
Got all kinds of shocks and sparks, and was wondering what was going on.
I was familiar with static-safe fuel hoses, so I explained that to him. For some reason the installer had used a non-static safe hose.
LUCKY it was diesel and not gasoline that would have exploded!
He replaced the hose with the proper one and the sparks and shocks ceased.
Sounds like that's what's happening with that hydraulic system.
Is the filter housing plastic (as it appears to be)?
Here's some details on ONE static-safe fuel hose...
Fill-Rite FRH07520 3/4" x 20' Fuel Hose
8" internal spring guard protects the hose from exceeding its bend radius, extending the life of the hose
Braided copper static ground wire prevents static discharge and ensures safe fueling
Dispenses diesel fuel, gasoline, grease, kerosene and petroleum oils
A blend of nitrile and PVC external materials provide rugged protection against cuts, abrasions, snags, and are resistant against puncture
This hose is designed for use with all electric pumps.
