Hi all Im new here. Im a proud owner of a Ford 8N. Its a front mount distributor. Converted it to 12v electronic ignition new plugs wire rotor cap and carb. Starts right up even in very cold temps. It idles but you can hear a continues skip. Until its warm it will not move without hesitating or stalling. Once warmed up it will run but with a little hesitation. When the PTO is engaged to operate the bucket or backhoe it really bogs down or will stall out. If the throttle is increased significantly it will work but its reved up way to much to be effective. When I put the electronic ignition in the magnet did not fit. I had to do some filing on the inside where it slips onto the distributor shaft. I called the manufacture and they said that shouldnt matter. So here I am with this piece of history and can not use it effectively. Thoughts. Thanks in advance
