Kind of OT Generator Questions
Lynn Patrick
2 questions for someone w/more electrical savvy then me - which includes MANY of you!
I need a simple wiring diagram to wire a starter/generator. All it needs is a battery, on/off/start switch, ammeter, & the starter/generator.
Also, do I need a special starter/gen (as is on my IH 154) or can any generator work?
Thanks!
L.Fure, it's for a "just because" project. I'm re-powering a Ford 120 mower w/a Wisconsin 2 cylinder. (I call it my Ford Funk In-Line Two) It has crank start that I want to change to electric. The cost of all the needed parts to change over using Wisconsin parts is EXPENSIVE!!!
(quoted from post at 12:58:56 03/14/18) L.Fure, it's for a "just because" project. I'm re-powering a Ford 120 mower w/a Wisconsin 2 cylinder. (I call it my Ford Funk In-Line Two) It has crank start that I want to change to electric. The cost of all the needed parts to change over using Wisconsin parts is EXPENSIVE!!!
tarter/generator is different animal to standard generator which can not produce enough torque to crank an engine.
