I am working on reworking my hydraulics. when I took it apart it had the original 3 ring piston and I have decided to replace it with the newer style. when I took the cylinder out there was quite a bit of trash in the cylinder and there are some scratches that are not that deep. I am thinking that I can just hone out the cylinder and call it good. has anyone done this before and how well did it work?
would I just be better off installing a new aftermarket cylinder?
the only reason I am redoing them is once the hyd. fluid warmed up it would not lift. I am almost positive the cylinder and the piston were not the problem to begin with. the gasket that goes in between the cylinder and the top plate was all but missing.
