david brodhead
I am in the process of removing front end stuff prior to doing a front axle pin removal. I want to remove the radius arms at the front axle
attachment point. The nut came off easily, but I can?t get the bolt to move. It seems to be really rusted in.i have tried PB blaster and tried
moving the bolt using a socket and a 3? breaker bar. Any ideas on removing these 2 bolts? Can I leave the radius rods attached to the front axle
and unbolt their other end and still do the front axle pin replacement ? I would then be dealing with 2 radius rods attached to the axle while
replacing the front axle pin.
