Order Ford 8N Parts Online
Re: **looking for a project loader for ‘49 8N**
Ultradog MN
03-12-2018 15:51:56
Are you Sure you want a loader?
Here's some food for thought:
A loader will make a dreadnought out of one of these little tractors.
They will wear your front end and steering out. You'll have to cut the grill to mount your hyd pump. The tractor will be long, clunky to drive and very hard to steer.
If you buy an old cheap loader chances are your hyd valve will leak, hoses will need replaced, cylinder rods will be rusted and pitted and will leak and be expensive to repair or replace.
If you need a loader at least 50% of the time then by all means get one. But if you just need it for occasional use consider what many of us do which is use a boom pole for lifting/loading stuff and a rear scoop for hauling rocks, dirt, tools, etc.
If I had only ONE tractor it would NOT have a loader on it. Loaders really suck unless you have a lot of use for one and if I had a lot of use for one I would buy a newer tractor with power steering and dedicate it to loader work.
Leave your handy, nimble N for the tasks it was designed for - plowing, mowing, etc, etc.
