Painting the letters on hood-fenders
Is there a template for painting hood and fenders letters on the tractor?
My hand is not steady for this task when painting with a small brush.
The tractor is a ford Jubilee,
About 6 years ago, i repainted my 8N. I ordered a decal kit and in the kit they had the Ford decals for the fenders and hood. They look perfect. Problem is, i dont know where I got the kit.
I have used decals and hand painted some. If your hands are shaky and you don't have someone else to do it for you, use the decals.
(quoted from post at 20:05:22 03/10/18)
(quoted from post at 23:02:38 03/10/18)
(quoted from post at 14:23:55 03/10/18) Decals and templates both available [b:7e89f0f88b]here[/b:7e89f0f88b] on YT.
Are those painting masks reuseable??
http://www.yesterdaystractors.com/Ford-NAA_Ford-Script-Painting-Mask_S67163.html
I bought a set once, they said one time use, not re-usable.
I can't tell you for sure if they would be, because I ruined them before I used them the first time! :oops:
Better luck next time Royse
(quoted from post at 23:11:42 03/10/18)
(quoted from post at 14:23:55 03/10/18) Decals and templates both available [b:b6adb76e0c]here[/b:b6adb76e0c] on YT.
Thanks, I probably won't buy them again, they were cardboard stencils.
As a side note, if one decides to order them, order the right ones for your tractor.
They are not all the same size. Seems like even 8N and NAA are different IIRC.
(quoted from post at 20:18:24 03/10/18)
(quoted from post at 14:23:55 03/10/18) Decals and templates both available [b:1dfee37c96]here[/b:1dfee37c96] on YT.
I'll just stick with my Desitin method
(quoted from post at 23:21:25 03/10/18)
(quoted from post at 14:23:55 03/10/18) Decals and templates both available [b:11be43ccae]here[/b:11be43ccae] on YT.
Back when we painted ambulances with single stage enamel we did basically
the same thing for hard to tape items. Door handles, window/light trim, etc.
Wheel bearing grease, Vaseline, boot polish, heavy wax, anything
that would not run when painted over but would wash off once the
paint was dry. It works fine. Still got to be fairly steady for application.
