How to adjust slack in steering wheel?
(quoted from post at 11:25:52 03/10/18) How do I get the slack out of the steering wheel, is there any place to make the adjustment?
On what model tractor? If it's an 8N, 2 bolt or 4 bolt box?
Since youve been around here since 2001 I'm certain you know you need a manual for your tractor.
Read it.
The process is a Very simple pair of adjustments to your steering sectors - like maybe one step harder than adding air to a tire.
A lot of variables here. If the slop is in the gearbox, its adjustable.
At least up to the point where it binds at full turn.
If the slop is in the drag links, tie rods and bushings, its repairable.
