removing a 9N distributor
When the distributor is removed is it necessary to note the position of the points and reinstall the same way?
Is it possible to mess up the timing when removing and reinstalling the distributor?
The tang has a wide side and a narrow side. So does the cam. Match them up off the tractor. Then, place the distributor on the tractor and turn it until you feel the tang slide into the slot before you tighten the bolts. Don't worry about the points. Did you set the timing after you set the points? Done a continuity check?
75 Tips
As Bruce said, its nearly idiot proof.
If you are going to replace the points or clean them, take a ruler, 1/4" drill bit and an ohm meter plus your feeler gauges, and your i&t fo-4 manual.
