Ken/Wa
I asked on the JD site, but asking here also, as many on here have older diesel
tractors. I have used Delo 400 for years in my 1990 JD 870, but now can only find Delo
400 sde. I know it is for lower emissions, but can I use it in the older diesel
tractor? Thanks Ken
(quoted from post at 11:32:09 03/06/18) I asked on the JD site, but asking here also, as many on here have older diesel
tractor? Thanks Ken
From the product data sheet:
Delo® 400 SDE SAE 15W-40 with ISOSYN® Advanced
Technology is a heavy duty engine oil recommended
for naturally aspirated and turbocharged four-stroke
diesel engines and four-stroke gasoline engines in
which the API CK-4 or SN service category and SAE
15W-40 viscosity grade are recommended. [i:b04c587a84][color=blue:b04c587a84]Delo 400
SDE 15W-40 is also backwards compatible with diesel
engines in which the API CJ-4, CI-4, CI-4 Plus and CH4
service categories are recommended.[/color:b04c587a84][/i:b04c587a84]
CUSTOMER BENEFITS
Delo 400 SDE SAE 15W-40 with ISOSYN Advanced
Technology is an API CK-4 heavy duty engine oil
specifically formulated for 2017 greenhouse gas (GHG
17) compliant diesel engines designed to meet lower
CO2 emissions and improved fuel economy, in addition
to EPA 2010 compliant low emission diesel engines
with Selective Catalytic Reduction (SCR), Diesel
Particulate Filter (DPF) and Exhaust Gas Recirculation
(EGR) systems. [i:b04c587a84][color=blue:b04c587a84]It is fully compatible with previous
engine models and previous API Oil Service Categories.[/color:b04c587a84][/i:b04c587a84]
Seems pretty clear cut to me.
TOH
Bi-Mart carries Delo 400 in 30WT and at a reasonable price. Unless you are dealing with cold temperatures, that viscosity should be fine.
