Jeff Hamilton
1952 8N, side mount, 12V conversion ? My tractor runs fine, almost all the time. I can?t track down what is causing an annoying problem. Here is what happens, using a 5 ft rotary mower (w/ORC!) I find that when I make a hard 180 degree right turn at the end of my row the motor cuts out, as if I turned off the key, ?.but just momentarily. It usually self corrects and I start another pass. At the other end of the pasture I pull a hard 180 to the left with no problem. Go down to the other end and go right and it?ll stutter again. I looked for a wire that could be grounding out, so far I have not found it. Also, the other day it was cold, so I started it up to warm up and walked back to the barn for something. A minute or two later I heard the tractor begin to die, as if the key was turned off. I quickly turned around to see it catch and speed back up again ? no explanation. Ideas?
