Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Swapping PTO Soon
Dollar Bill
02-09-2018 02:03:51
As others advised, it's best to bite the bullet and give it a thorough cleaning. It will give you better access to pull the lift cover as well as the pump.
If you're under a time crunch, I would follow Soundguy's method:
Drain oil overnight and add 3 gals kerosene, 2 qts ATF, 4 pints 90% rubbing alcohol. Cycle the hydraulics once then exhaust to clear anything in the pump that might be hanging around. Disengage the PTO and make a few low speed laps around driveway. Then drain and refill with new oil.
Theory is the kerosene makes it dump fast and dissolve most emulsion it finds. The detergents in the ATF will suspend any crud it can and the alcohol will evaporate any water in the system.
