TractorLinks.com
Order Ford 8N Parts Online
Re: 1950 8N No Fire
R Geiger
02-08-2018 14:05:36
well to start with, which 8n do you have, is the dist on the front with a square coil or on the side with around coil.
second plugs should be gapped to 0.025" not 0.015"
front mount points are set to 0.015" side mount to 0.025"
You said 50 and that could be either of the two. You said original resistor that would only be on the front mount type dist.
If you have a round coil, you could get rid of the inline resistor if you installed a 12 volt coil. those inline resistors are all over the place in resistance.
It does sound like you have a late 50 tho with the round coil. The only time you will read voltage is with the points closed.
make sure you have ethe firing order correct, 1,2,4,3 front to back.
