Voltmeter Hookup Suggestions
allenlane
Dad never was a believer in ammeter's so my 45 2N has a voltmeter instead, and I'm just going to leave it. Anybody have an opinion on the best way to wire it up? Also a 12V conversion. I'm thinking of pos side on the starter solenoid (same post as pos batt cable and one wire alt wire) and ground to the closest location. I do have and mostly followed Jason's wiring diagram (I have a starter switch instead of push start).
+ on Voltmeter to switched side of ignition switch. - to convenient ground. If the voltmeter is connected to the battery all the time it will eventually run the battery down as it does draw a small amount of current.
later
deano
