8N no 3pt lift
DGK
3pt lift will not raise, PTO on does notmake any kind of noise like pump not even working. THANKS FOR ANY
HELP.
(quoted from post at 17:15:30 01/21/18) 3pt lift will not raise, PTO on does notmake any kind of noise like pump not even working. THANKS FOR ANY
HELP.
is the pto shaft turning? have you had real cold weather? if so water in oil may froze and cracked the pump
Thanks I thought i read 16 to but guess i didn't. will be a couple days but will try looking in there Thanks.
Took plate off side =, started tractor with pto on, only oil moving was around pto shaft, guess I need to drain oil and see what drives pump.
(quoted from post at 16:22:34 01/22/18) Took plate off side =, started tractor with pto on, only oil moving was around pto shaft, guess I need to drain oil and see what drives pump.
With the tractor not running, can you see the control rod moving back and forth when you move the hydro lever? Reach in under the oil and feel if the control rod end is still in the socket of the control lever and moving that back and forth.
(quoted from post at 17:22:34 01/22/18) Took plate off side =, started tractor with pto on, only oil moving was around pto shaft, guess I need to drain oil and see what drives pump.
he pump is driven by the PTO shaft which runs thru the center of the pump.
(quoted from post at 19:15:30 01/21/18) 3pt lift will not raise, PTO on does notmake any kind of noise like pump not even working. THANKS FOR ANY
HELP.
As shown in photo, the control arm needs to push rocker all the way against the pump casting when lifting. Remove the right inspection cover (dipstick side). With engine running and PTO engaged, reach in the right side and push the control rod forward with your hand. If it works then it is possible the cam follower pin has worn through or fallen out.
Pump isn't making any noise because there isn't a load on it.
"started tractor with pto on, only oil moving was around pto shaft"
Go back and re-read tip # 16. Did you try and raise a heavy implement? If you did not have a load on the pump, that is exactly what you will see. And it doesn't tell you much.
" guess I need to drain oil and see what drives pump. "
Check out tip # 39. If you don't have the manuals or a basic understanding how these tractors work, you will end up spending a bunch of money and wasting a lot of time fixing stuff that isn't broke. And breaking other stuff in the process.
75 Tips
