Sounds like [b:7bdd941ccd]this.[/b:7bdd941ccd] This is the second start today.
The first was about the same but obviously smokier with all the pre-lube.
Engine has 10W-30 oil in it and 50 PSI of oil pressure cold.
That's at the speed you hear. I don't have the proofmeter
cable back on it yet to tell you what the RPM actually is.
I need to run it a while then re-torque the head bolts.
Still got a lot of work to do before this tractor is "done".
Once ran a while I plan to convert it back to a 6V system.
No particular reason for that, other than because I want to.
The 12V components shown have been on it for a few years
now and work fine as they are. I thought it might be nice to
have the 12V system to spin the new engine for a while.
