davyfireball
yesterday I was pushing snow into the ditch and the blade went into the ditch. The ditch was 4 ft deep when I went to lift the blade it wouldn't lift. I drug it out of there and went home. I looked and the take off wasn't working ( lever was not engaged) I engaged the take off again. Tried to use lever to lift the blade and the control arm wouldn't move much. I stuck a lever in it while it was running and( pried forward) And it started working right.
I know the exhaust valve was stuck open. But did going into the ditch put the pump in a small bind? Or is the pump getting dirty. I cleaned it 10 years ago. But all I use it for is snow.
