53 axle replacement
we pulled the right side axle apart on my 53 NAA, splines are shot, hub is shot and the shims where in pieces. The axle nut was just a nut, no spring no slot and no key. the axle has no slot for a key or spring. is it possible they have been replaced once before?
Good Pix when you get a new axle post a pix of it to go with this post.. I have seen the axle turned down and re-threaded...
It is worn out. My question was why is it different than it should be. It doesn't really matter because I have to replace it I was just curious if anyone else has seen an axle like this.
What part of the world are you located in? I have an axle
here in central Michigan you could compare it to if you're close.
