Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Help to identify bolt
brianlivingstone
01-10-2018 09:27:33
Can someone please tell me the purpose of the bolt circled in the picture. I thought it was a drain plug until I removed it
Thanks . Brian
BrianLivingstone
01-11-2018 15:30:17
 Re: Help to identify bolt in reply to brianlivingstone, 01-10-2018 09:27:33
Do you think I have a chance of doing damage to the tranny?
It seemed to go back into the same place and it drove fine last night.
howdy1960
01-11-2018 08:14:59
You did want to rebuild the tranny this year didn't you?
Note to self: "DO 'NOT' REMOVE THIS BOLT!"
Maybe I should black marker it above the bolt as I 'know' I'll forget where I put the note lol
BrianLivingstone
01-10-2018 15:12:17
i apoligise for the photo. I knew it was off 90 degrees but I didn't realize I had it reversed.
Good eye
HCooke
01-10-2018 14:19:24
That picture is reversed!
JMOR
01-10-2018 11:23:40
on second thought..........isn't that the wrong side for that?
R Geiger
01-10-2018 11:05:34
You may have gotten lucky, looks like it is pin for the reverse idler shaft. Parts books are great.
JMOR
01-10-2018 11:03:55
Secret Squirrel nailed it......pins the reverse idler gear shaft.
SECRET SQUIRREL
01-10-2018 10:34:19
It is a pilot bolt that holds a shaft in place, or at least is on mine.
brianlivingstone
01-10-2018 10:48:47
 Re: Help to identify bolt in reply to SECRET SQUIRREL, 01-10-2018 10:34:19
It looks like a 1/4" smooth shaft that is 3 1/2 - 4" long . I was afraid that I may have unhooked something on the inside when I pulled it out.
JMOR
01-10-2018 10:30:24
looks about correct height for oil level check plug
Blue Jay
01-10-2018 10:13:49
Probably just an access point to a set screw, mine is just a 1/8" pipe plug. Your picture has me a little confused, looks like the right side of the tractor but clutch and brake are on the left side and 3 point quadrent on the right.
My tractor is a 46 also that Dad bought the year I was born.
brianlivingstone
01-10-2018 09:29:58
Try again!
brianlivingstone
01-10-2018 09:40:19
 Re: Help to identify bolt in reply to brianlivingstone, 01-10-2018 09:29:58
46 Ford 2 n
