2N 3 point will not stay down
allenlane
Got my hyd pump all put back together and now my 3 point will not stay down. It raises and lowers fine but when I release the control it comes back up. Do I just need to calibrate the quadrant?
There is a cork shaped disc that goes between where your control lever is attached to your tractor, there is a chance that this has gone bad. The handle will want to rise up if your cork disc has gone bad. You can get a sheet of cork at walmart or any hobby store and cut it out and place it in there and it will create the friction to keep the lever down.
The guys on this forum helped me out with this same problem a few years ago, replaced it and haven't had a problem since. Glad it solved your problem too.
