tractor gal
Hello, all.
Haven't been here in a LONG time. That's a good thing...little 2N beauty has been putzing around with no problems. But, now I am replacing a water pump and have a question. I've removed the fan, belt and old water pump. There was no sign of a gasket. The new pump has a face plate already installed with a gasket already behind it. There is a metal disc with a small hold in it still at the block and it seems to have some silicone gasket sealant or some similar material squeezing up from behind and also a little worm of sealant coming out of that small hole. That tells me that the disc needs to be removed. However, because I am rather "klutzy," I don't want to start prying around on this thing. I don't have a picture of the block without a water pump so I can't visualize what it should look like. I watched a youtube of a replacement and the block appeared just to be a hole. Would someone mind giving me a mental picture of this? If I remove the disc, there must be something behind it in order for it to have sealant, right? The second gasket would be coated with sealant and placed on the plate of the new water pump? Anyway, I always appreciate the kind help that I receive here. Life is good when you have a 2N.
