(quoted from post at 12:07:07 12/19/17) As JMOR explained, the early 8Ns used a 3-Wire/3-brush generator. In early 1950 it was changed to a 3-Wire/2-Brush style and also a new VR introduced. The original AUTO-LITE VR's mounted on three rubber feet/insulators. The aftermarket VR's sold today do not use the rubber feet -to be discarded when replacing the VR. The new VR's should come with a mounting bracket that also will house the light switch if used. The 2-brush generator obviously does not have the 3rd Brush adjustment screw on the back plate. Do you have the original, correct 8N-10145 tensioning arm on it? Also, it would be a good idea to polarize the new VR once it is connected and before you apply power. Get a copy of Wiring Pictograms by JMOR -an essential document to have. If you want to sell me your original AUTO-LITE voltage regulator, email me.
ORIGINAL 8N ELECTRICAL WIRING w/AUTO-LITE VR:
<center><img src="https://i.imgur.com/oImEDIXl.jpg"></center>
ORIGINAL 8N-10000-A GENERATOR & AFTERMARKET VR:
<center><img src="https://i.imgur.com/dSPH1FQl.jpg"></center>
NEWER VOLTAGE REGULATOR WITH MOUNTING BRACKET/LIGHT SWITCH: <center><img src="https://i.imgur.com/enysCFLl.jpg"></center>
Tim Daley(MI)
50 52 FORD 8N Voltage Regulator
