1st problem - bent control plunger - got it straight with a torch
2nd problem - water in hydraulic/trans chamber (PO left plunger guide/cover unbolted so rained inside)
All fluid is drained, I don't want to take the lift cover off right now, so through inspection plates see that the control valve is not connected to the bottom of the forks.
1st question - is there a trick to spreading the forks and getting the valve "T" back in the fork?
2nd question - what else should I be looking for from a bent plunger?
Before I realized water was in the system, I actuated the lift and it lifted fine but would not go down with the lever. After I drained the system, after a few seconds something released, more fluid came out, and lift lowered. What does that indicate?
Also, is it normal for the PTO to make a little grinding sound when engaged? I doubt it. PTO runs fine though when engaged.
I snuck a few more questions in there.
