Had gas seeping onto the glass of the sediment bowl for a while now. Replaced the bowl gasket, checked the glass edge, seepage still there.
Got a good light and checked the issue more closely, dried everything carefully and watched for a few minutes. Then I noticed some gas slowly seeping out around the plug on the side of the housing.
Tightened the plug...still seeping. Removed the plug, cleaned the threads on the housing and the plug with a Q-Tip and lacquer thinner, applied a bit of sealant, reinstalled. twenty four hours later...no leak.
I know, I know, I should have checked more closely before I let this thing kick my butt.
Thought you might like some pics.
Also included a couple of the Idiot light setup (had an extra hole in the dash to do something with).
