Scott(Ks.)
The light switch on my 8N has been bad for several years. I was In TSC the other day and saw a compatible switch. I brought it home and threw it on the bench. Today I was feeling guilty that I had been so lazy I decided to put it on the tractor.
First disconnect the battery, then remove the tool box. The last time the tool box was off was in 1977. Do you know how much junk you can get in that little box in 40 years?
The switch went in well and I can shut the lid on the box. I also now have head lights and a work light.
I also cleaned the posts and cables on the battery and checked the date. It's only 9 years old, and yes I use a float charger.`
It was an easy and good day.
