8N Draft/position Control Lever Issue
My lever seems to be locked in position control (vertical). I can't get it to go forward to draft position. The spring and detent ball are clean and free and the shaft moves just slightly when I wiggle the lever. Any suggestions before I pull the top cover? I don't necessarily need draft control, but I'm the kind of person that likes to have everything working properly.
(quoted from post at 12:11:15 11/22/17) My lever seems to be locked in position control (vertical). I can't get it to go forward to draft position. The spring and detent ball are clean and free and the shaft moves just slightly when I wiggle the lever. Any suggestions before I pull the top cover? I don't necessarily need draft control, but I'm the kind of person that likes to have everything working properly.
t does require a bit of hand pressure going into draft, as you are compressing a spring. Of course the toggle mechanism that you are trying to operate could be rusted in place, too.
