RawkFarmer
Good morning, I did not see my question in any of the threads, so:
I am in the process of changing the ignition points for my front-mounted, 6 volt 2N and wanted to know: how exactly does one go about changing out the thin copper strip linking the condenser to the points? The old strip appears to be attached on the left side by a hollow rivet (into which the special screw threads in), rather than a screw, and I didn't want to break anything or make some change I couldn't correct. Are there any suggestions as to how to remove that strip's left side?
Thank you!
Thank you!
