Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
601 freeman loader bracket needed and hydraulic connections
lynnvillekytractor
11-12-2017 21:01:43
I have a 1950 late model 8n and a 601 freeman loader I want to install on it. I need a front bracket and the info on connecting the hydraulics. Any help is appreciated.
lynnvillekytractor
11-17-2017 11:00:57
 Re: 601 freeman loader bracket needed and hydraulic connecti in reply to lynnvillekytractor, 11-12-2017 21:01:43
jl ray
11-16-2017 06:21:01
 Re: 601 freeman loader bracket needed and hydraulic connections in reply to lynnvillekytractor, 11-12-2017 21:01:43
I would have to go look but I think there's a bracket for a pump mount at my dads. The loader was a freeman trip bucket but I don't know the model. I'm sure if I looked in dads old manual box a manual maybe there as well. The loader is long gone but I'm fairly sure the pump and bracket are still there. Maybe even the connection drive rod assembly. I'm positive the oil tank is as I'm planning on using it on another project. I won't be able to go look till after turkey day. E mail me next week end to remind me to look if you think this maybe what you want.
razorray1024@gmail.com
R Geiger
11-13-2017 07:45:40
Just remember if you are going to plumb into the test port, you will have to chain the lift arms down.
TheOldHokie
11-13-2017 06:04:08
Is this a trip bucket loader? Got any pictures?
TOH
Bruce (VA)
11-13-2017 07:14:28
 Re: 601 freeman loader bracket needed and hydraulic connecti in reply to TheOldHokie, 11-13-2017 06:04:08
Excellent question!
I just assumed it was a trip bucket......... :)
Bruce (VA)
11-13-2017 05:06:24
You'll need to make a front bracket. It attaches to the two front pan bolts and the pivot pin.
The loader cylinders are plumbed off the test port. The line comes up between the right running board and tranny and then crosses over the tranny cover to a T where the rubber lines connect. Do yourself a favor and buy quick disconnect fittings.
Be very, very careful w/ the threads in that test port. That pump port is threaded 1/2-20 straight thread.
I'd get a test port fitting from The Old Hokie and modify it to fit your plumbing to the cylinders. http://windyridgefarm.us/
lynnvillekytractor
11-16-2017 22:21:15
 Re: 601 freeman loader bracket needed and hydraulic connections in reply to Bruce (VA), 11-13-2017 05:06:24
Thanks guys for the info. It is a trip bucket. I'll post the brochure if I can figure out how.
