TractorLinks.com
Show Parts for Model:
Re: Rear Fender Bolts
Den N Ms
11-10-2017 11:29:52
Gkingery,Here ya go
8N colors
center housing red
electrical- battery cable unpainted
center housing- touch control lever red
electrical- battery ground strap unpainted
center housing- pedals: Brake red
electrical- battery tray red
center housing- pedals: Clutch red
electrical- distributor red
center housing- rear axle housings red
electrical- gauges: (ammeter) bezel black
center housing- rear axle hubs red
electrical- gauges: (oil) bezel black
center housing- rear axle lug nuts plated
electrical- gauges: (proof) bezel black
center housing- rear brake drums red
electrical- generator and pulley red
center housing- three point hitch red
electrical- ignition: Switch and key unpainted
center housing- drawbar red
electrical- spark plug wires unpainted
center housing- pto lever red
electrical- spark plugs unpainted
center housing- pto shaft cover red
electrical- starter red
electrical- starter button red
electrical- wiring harness unpainted
engine- carburetor red
sheet metal- dash gray
engine- carburetor air cleaner red
sheet metal- fender mounting bolts plated
engine- carburetor choke knob plated
sheet metal- fenders gray
engine- carburetor fuel line unpainted
sheet metal- grille gray
engine- carburetor fuel shut-off valve unpainted
sheet metal- hood gray
engine- crankcase breather cap red
sheet metal- running boards red
engine- fan belt black
sheet metal- seat and spring black
engine- fuel system: Sediment bulb unpainted
sheet metal- side panels gray
engine- fuel tank galvanized
steering- front axle hub red
engine- head, block, and oil pan red
steering- front axle lug nuts plated
engine- linkage unpainted
steering- front axle spindle housing red
engine- manifolds red
steering- radius rods red
engine- oil filter red
steering- steering wheel acorn nut plated
engine- radiator black
steering- tie rods red
engine- radiator cap black
transmission gearshift knob black
engine- radiator fan red
transmission- gearshift red
engine- radiator fan shroud red
transmission- gearshift boot black
engine- radiator hose black
transmission- housing red
engine- throttle lever plated
wheels- front rims gray
engine- solenoid plated
wheels- rear rims gray or silver
wheels- rear centers gray
Delano, NC
11-10-2017 16:53:23
 Re: Rear Fender Bolts in reply to Den N Ms, 11-10-2017 11:29:52
I thought dash was red. Must have painted my the wrong color.
Den N Ms
11-11-2017 06:56:50
 Re: Rear Fender Bolts in reply to Delano, NC, 11-10-2017 16:53:23
It should be RED I don't know how that got changed to gray,edit button again.
8N colors
center housing red
sheet metal- dash red
Tim PloughNman Daley
11-11-2017 04:52:40
All 8Ns had the dash painted Ford Vermillion (RED) M-2822 -who said different? All 9N and 2N Models had everything -cast iron and sheet metal parts painted Ford Dark Gray -M2888.
Tim *PloughNman* Daley(MI)
gkingery
11-10-2017 11:51:13
Den N ms in the color chart you posted it states: sheet metal-fender mounting bolts plated.
Are those the bolts into fenders or the 5/8 mounting bolts to rear axle?
Dell (WA)
11-10-2017 14:21:16
 Re: Rear Fender Bolts in reply to gkingery, 11-10-2017 11:51:13
kingery.......fender-to-axle bolts, 5/8x6-1/2, carrage bolt, plated. Which is the pitts to find, 'cuz they stop at 6" even. The fender-to-rib were round headed rivets. Me? What ebber ya kenn find to fitt ...unless... yer entering yer tractor in a judged competition. And I don't go there........Dell
