CRANK WON'T TURN
J B
New User
I had a 9n ford tractor engine rebuild but it wouldn't run right. I replaced the carb. the distributor and it still wouldn't run right. You could turn the crank with a wrench easy. So i decided to tear it down myself. I lapped the valves and rehoned the cylinders. I torqued the piston rods to 35 ft.lb. After that i couldn't turn the crankshaft , it wouldn't budge. I loosen the rod nuts and it would turn fine. Does anybody have any answers. It doesn't make sense.
JB
(quoted from post at 21:57:54 11/09/17) I had a 9n ford tractor engine rebuild but it wouldn't run right. I replaced the carb. the distributor and it still wouldn't run right. You could turn the crank with a wrench easy. So i decided to tear it down myself. I lapped the valves and rehoned the cylinders. I torqued the piston rods to 35 ft.lb. After that i couldn't turn the crankshaft , it wouldn't budge. I loosen the rod nuts and it would turn fine. Does anybody have any answers. It doesn't make sense.
JB
makes sense to me. You have the rod bearings/caps installed incorrectly.
TOH
The rod caps must remain with the rods they came off. Mixed rods and caps won't work.
Match the numbers.
Zane
(quoted from post at 18:35:15 11/10/17) The rod caps must remain with the rods they came off. Mixed rods and caps won't work.
Match the numbers. Thank you
Zane
