TraktorFreunde
Sorry to post this, but I've looked at a few older posts, and I''m not sure they help.
I changed my oil and had the ol' leak out of the filter housing, but not the top bolt. I tightened it to the FO-4 manual specs. My concern is that the filter isn't right (bought from just 8n's) or that the gasket is not right (it''s a round rubber o-ring, not a flat gasket).
I've attached a photo. My other concern is if something clogged the line going out of the housing?! Or else I''ll try not tightening the bolt so much or use the old gasket, unless you tell me the filter is a no go.
Sorry, no photo of the gasket that came with it. It also included 3 thin copper washers, of which I have no idea what they would be for.....
Filter number from the box is: ML1380 from 'Fil filter'
Thanks. Mike
Thanks. Mike
