[b:5eccf351f2][i:5eccf351f2]
Had a flat tire on my snowmobile trailer, and found the valve stem was broken, and leaking air. (tubeless tire). So I proceed to jack up the axle, and remove the lug nuts!!!! OH YEH......could not remove the wheel, from the axle.???? Beat on the back of the wheel for a good 20 min.???? Still won't budge. What the hey.....Take the 'bearing buddy' off.....remove the outer bearing,...remove the wheel, tire and hub, take the whole dam thing down to the Auto shop, to fix the valve stem, and see what the 'H', is holding the wheel tight to the hub.
This is what he found!!!!?????
Seems like the last tire guy, had the same problem I was having, so he just.....CUT the wheel off that was stuck on, and, installed a dif wheel and tire.
Took a press to bust that center off the hub!!!
What a dumb butt that guy was!!!!! No wonder that the tire shop closed their doors!!!!
GB[/i:5eccf351f2][/b:5eccf351f2]
