Steve,Yes it is a 9N or a early 2N, it looks like it also has a Sherman combination transmission in it and that makes it a good buy if it is in good shape.Even has a fresh carburetor adjustment.lol
(quoted from post at 19:22:36 10/16/17) Steve,Yes it is a 9N or a early 2N, it looks like it also has a Sherman combination transmission in it and that makes it a good buy if it is in good shape.Even has a fresh carburetor adjustment.lol
OH YEH......That carb adjust will sell it FAST!!!????
:lol:
GB[b:42480f3ffb][i:42480f3ffb][/i:42480f3ffb][/b:42480f3ffb]
I would guess it's what's left of a fairly early 9N.
I don't see a neutral safety start button on the transmission cover.
Sheet metal, hubs and fenders look to be later though.
I suppose it could be backwards and the trans was changed.
That's a lot of years to guess at all the changes. :)
Yup, 9n, probably late '40 to mid '41 from what I can see it the photos. As others have said probably a Sherman combo. It could also be a Sherman creeper but the likely hood of that is very rare in which case his asking price would be worth less than the value of the Sherman creeper.
Kirk
I did look at the shifter. Since the Sherman combo and the Sherman creeper use the same shifter handle it is impossible to tell the difference by just looking at shifter. Just like it is impossible to tell the difference between the Sherman step up and Sherman step down just by looking at the shifter because they were the same.
I do agree that because the creeper is so rare that it's probably a combo.
Kirk
It does look to me like it has that bolt, either that or something on where the bolt should be.
(quoted from post at 02:47:01 10/18/17) Left rear rim has been replaced. Rear tires are very old should be replaced asap. Price ???
I understand you are looking at $800 - 1000 for rears. Hope someone with actual experience will chime in.
