roxndirt64
New User
Heres a weird one. Converted my 9N to 12 volt. Used a GM alternator. Jumped the T1 and T2 terminals together. Installed a ballast resistor (Napa ICR13) inline to 6V coil. Started it up everything was charging good. Had it running long enough to play around with the carb that I just rebuilt. Shut it off and wouldnt restart. No power to coil. Disconnected wire at coil, and then had power to coil wire. Should have had 2 resistors inline probably. Replaced coil with a 12V coil. Tractor started up but cant read battery voltage anywhere. Shut the tractor off and turn key on not running and can read voltage. Anyone else run into this?
