Having problem starting Ford 9N that has been converted over to 12V battery with a resistor.
Does not appear to be getting power at the spark plug or off the distributor (green cap that spark plug wire plugs in).
I connected the spark plug wire to a screwdriver and held it over the spark plug and did not see any arc.
I read in Bruce Haynes 75 Tips in #38 if the ignition was left on and points were closed when the engine stopped, that the points could be burned and possibly the coil...
From little experience I have with points, I remember a person can use a small fine file and clean and reset... but I don't know about the coil... Am I looking at replacing the coil?
Any guidance would be appreciated.
